TwinTurbo.NET: Nissan 300ZX forum - I would check compression. The symptom of having smoke
MixManMash
on July 02, 2012 at 6:53 PM
I was using an endoscope and I see oil in the joints...
posted by Black95
on July 02, 2012 at 06:32 PM
when you let off throttle is what I had happen when the ring landings on #6 went toast.
Black95
18:32:58 07/02/12
I would check compression. The symptom of having smoke -
MixManMash
18:53:01 07/02/12
But would that also explain the oil in the charge pipes. (n/m)
Black95
19:05:13 07/02/12
Yep. It happened to me in that same fashion.
MixManMash
19:23:51 07/02/12
Any other symptoms that would indicate this is the case? (n/m)
Black95
20:48:04 07/02/12
Not really. Just a lotta smoke when you get your foot out
MixManMash
21:06:19 07/02/12
Definitely will do a compression test, but the smoke is only
Black95
22:39:48 07/02/12
Could be possible that the CHRA on your turbo(s) is letting
MixManMash
23:21:37 07/02/12
